Easy
You don’t have to be a rendering expert to create photorealistic images of your 3D model. Simply import your data into KeyShot, assign materials by dragging and dropping them onto the model, adjust the lighting, and move the camera. Done. You see everything happen instantly right in front of you. Learning KeyShot literally takes only a few minutes.
Fast
Everything inside KeyShot happens in realtime. KeyShot uses unique rendering technology which makes it possible to see all changes to materials, lighting, and cameras instantly. You don’t need to hit the render button and wait for minutes or hours to wait for the results. As soon as you assign a material to a part, you will see the change immediately.
Accurate
KeyShot is the most accurate rendering solution for your 3D data. KeyShot uses scientifically accurate materials and real-world lighting to help you create the most stunning images possible. KeyShot is the only application that is certified by the CIE for accurately simulating lighting in computer graphics.
KeyShot 3D rendering materials example
Unparalleled flexibility and speed with “drag and drop”, scientifically accurate materials in a realtime rendered interface.
Powerful Architecture
KeyShot doesnʼt require any special hardware or graphics card. KeyShot takes full advantage of all cores and threads inside a computer. As your computer gets more powerful KeyShot becomes faster. The performance scales linearly with the number of cores and threads in your system. If you double the amount of cores, you double performance and cut render time in half.
Tight Integration
KeyShot is tightly integrated with your 3D data. When you import 3D geometry, KeyShot maintains the entire model structure including part and assembly names. Changes made to your model in 3D can import back into KeyShot without having to reassign materials or lighting. In addition, KeyShot can also be accessed directly from within many 3D software packages through a plugin.
Large Data Sets
Since KeyShot is CPU based, any imported data is stored in RAM – not the video card. This allows KeyShot to handle extremely large data sets. There are no restrictions on the size of the data set as long as the computer has enough memory available. KeyShot is highly optimized which makes it possible to work with models with tens of millions of polygons even on a laptop.
Amazing animation
KeyShot’s revolutionary new animation system brings a whole new level of creating animations quickly and easily to your product development pipeline. KeyShot doesn’t rely on inserting and managing keyframes. Instead, apply individual transforms (rotations, translations, etc.) to set up new animations with a click of button, and update materials and lighting as the animation plays.
KeyShot 3D animation
Try KeyShot Now
